ImSarita
Jan 26, 2022Aspirant
Netgear Nighthawk C7100V cable Modem router
Every other icon except Phone 1 and Phone 2 are lit. Contacted Xfinity (ISP to no avail). Xfinity transferred call to Netgear Support Netgear Support had tried to get me logged onto 192.168.0.1. Then...
- Jan 28, 2022
Any progress on this?
Contacted Xfinity (ISP to no avail). Xfinity transferred call to Netgear Support Netgear Support had tried to get me logged onto 192.168.0.1. Then the call dropped.
Can this problem be fixed or should I buy a new product?
Any recommendations?
Thank you.
Kitsap
Jan 27, 2022Master
Yes, you can log in to the router to obtain status and other information. See attached snip from the user manual.
Under the advanced tab you will find both a Modem status page and a Voice status page.
There is a good chance your voice service is not activated. That would require help from your ISP. There is a group of help support from Comcast that specializes in activating user owned modems. You may have to be presistent and try more than once.
ImSarita
Jan 28, 2022Aspirant
Hi
I was just about to post that the issue has been resolved.
An Xfinity tech came out. He, along with an in-office agent, figured out the provisioning was not done. The in-office tech had to "rebuild the home phone number" into the new modem. After a restart of the modem, the phone lines are operable.
- FURRYe38Jan 28, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
