NiveusT
Feb 13, 2022Aspirant
Netgear Nighthawk C7800 - Any Firmware updates? Cox ISP says they have no firmware they can push.
Are there any updates to the firmware at all? I contacted my ISP and they said there are none on their end, but... Perhaps there's something with Netgear personally that I can get? I went to the C...
Feb 13, 2022Guru - Experienced User
ISP's rarely update firmware. Netgear sends them the firmware but it costs them $ to certify it. so they don't.
And you've found the sad circle of "its their fault" that you go through with ISPs and manufacturers.
Its why we usually recommend buying the modem sperate from the router.
What issue are you having you think a firmware update might help with?
NiveusT
Sorry, tried to delete one of my replies but it wouldn't let me for some reason.
Thanks for the help @ both of you :)
