ElderAgent
Sep 25, 2022Aspirant
Netgear Nighthawk C7800 Low Speeds on Lan and Wifi
Hi Community, I have been getting slow speeds on my C7800 from the get go. I just moved thinking that my previous place was the issue with my slow speeds but I am getting the same issues at my ne...
ElderAgent
Sep 26, 2022Aspirant
To clarify the firmware, it is Firmware Version V6.01.07
As for resetting to factory settings, I gave it a shot and made sure the settings mentioned were disabled and the results are about the same (got a slight boost.) I couldn't find the Smart Connect settings within the router settings and I looked up Dynamic QOS on the C7800 and apparently this router doesn't support it so I wasn't able to do much with that.
I looked up if my ISP supports IPv6 and it does and I made sure it was enabled, I even tested out disabling it to see if it made any difference and it did not.
I have also tried multiple cat5 cables, verified my network drivers are up to date, different coax cables.
I'm considering at some point just buying a more simple modem and seeing if that will make a difference.
I have a screen shot of my wireless setup to show that smart connect isn't there.
Smart Connect missing from settings
Kitsap
Sep 27, 2022Master
I have an R7800 so there may be some details that are different.
Your firmware version V6.01.07 is current.
Understand no QOS.
Understand no Smart Connect.
I also keep 20/40 coexistence disabled.
It is time to look at your cable connection power levels and your correctables/uncorrectables counts.
It is easier to copy and paste the screens to a word processing document and then attach to the reply as a PDF file. That way you do not have to wait for a moderator to approve your image file.
- ElderAgentSep 29, 2022AspirantIs the 20/40 coexisting a setting, not sure where that is?
Also where can I find this data?
"power levels and your correctables/uncorrectables counts"- FURRYe38Sep 29, 2022Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router - KitsapSep 29, 2022Master
ElderAgent wrote:
Is the 20/40 coexisting a setting, not sure where that is?Advanced -> Setup -. Wireless Setup - See attached screen snip.
- ElderAgentOct 01, 2022Aspirant
Thanks for the reply guys, I have disabled 20/40 coexisting and I have attached the the cable connection as requested in pdf format.
