ElderAgent
Sep 25, 2022Aspirant
Netgear Nighthawk C7800 Low Speeds on Lan and Wifi
Hi Community, I have been getting slow speeds on my C7800 from the get go. I just moved thinking that my previous place was the issue with my slow speeds but I am getting the same issues at my ne...
Kitsap
Sep 27, 2022Master
I have an R7800 so there may be some details that are different.
Your firmware version V6.01.07 is current.
Understand no QOS.
Understand no Smart Connect.
I also keep 20/40 coexistence disabled.
It is time to look at your cable connection power levels and your correctables/uncorrectables counts.
It is easier to copy and paste the screens to a word processing document and then attach to the reply as a PDF file. That way you do not have to wait for a moderator to approve your image file.
ElderAgent
Sep 29, 2022Aspirant
Is the 20/40 coexisting a setting, not sure where that is?
Also where can I find this data?
"power levels and your correctables/uncorrectables counts"
- FURRYe38Sep 29, 2022Guru - Experienced User
Under Advanced Tab/Advanced Settings/Wireless Settings
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router - KitsapSep 30, 2022Master
ElderAgent wrote:
Is the 20/40 coexisting a setting, not sure where that is?Advanced -> Setup -. Wireless Setup - See attached screen snip.
- ElderAgentOct 01, 2022Aspirant
Thanks for the reply guys, I have disabled 20/40 coexisting and I have attached the the cable connection as requested in pdf format.
- KitsapOct 02, 2022Master
ElderAgent wrote:Thanks for the reply guys, I have disabled 20/40 coexisting and I have attached the the cable connection as requested in pdf format.
There is no one magic answer. When you shut off the 20/40 coexistence, run a Wi-Fi throughput test on several of your wireless devices and see if it helps the situation.
Your downstream power levels are significantly high. Netgear says they should be between -7 and +7 dBmV. The power level situation should be corrected by your service provider. Make sure the ISP checks it all the way to your gateway, not just to where the wiring enters your house. Power levels being high can be just as much of a problem as their being low.
See here for Netgear reference on power levels: https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
