AyeeItsWillis
Nov 23, 2021Aspirant
Netgear Nighthawk c7800 low upload speeds
So I just recently noticed that my upload speeds on my c7800 modem router have been really low on my gaming consoles. Download speeds are what they have always been, but upload speeds have gone from ...
AyeeItsWillis
Nov 27, 2021Aspirant
So I went out and bought the Netgear Nighthawk CAX80 just to see if the C7800 was the problem. Nope still getting low upload speeds. So now I know that it is a problem with my ISP. Didn’t read this reply until just now. I checked the white coax cable that is connected from my modem to the outer box and it looks fine. I did notice that the black coax cable that is connected to the outer box that goes who knows where is a bit split open near the end of the cable. Would that be the line? Also I do not have any splitter, amplifiers, or any of that. Thanks.
PS. I don’t know much about this stuff so forgive me for my confusing explanations.
Nov 27, 2021Guru - Experienced User
I did notice that the black coax cable that is connected to the outer box that goes who knows where is a bit split open near the end of the cable. Would that be the line?---tough to know without being there to trace it. But if its a coax cable that incoming from the street, it sure could be your problem. And if 2 different modems exhibit the same problems, its more indicative of the line being the issue. Did you check with the ISP?
