MikeAble
Apr 15, 2021Follower
NetGear NightHawk C7800
I just purchesed a Netgear NightHawk C7800 so that I can could get Gig Speed. Not getting anything close VIA Hard Wired. Wiresless ~400mbps. Cable companly tested the line at the modem and I'm ge...
Apr 15, 2021Guru - Experienced User
After changing speeds, did you factory reset the router?
Try resetting it. During the install, leave qos, parental controls, access control, and traffic monitoring all disabled.
Then test your wired speeds.
