meglo1
Mar 14, 2020Follower
NETGEAR Nighthawk Cable Modem & ATT Uverse
I purchased the NETGEAR Nighthawk Cable Modem CM1200 on Amazon. The headline stated "Compatible with all Cable Providers", and after I ordered it I then (after the fact) noticed it says in the fine p...
qxinfinity
Aug 27, 2020Aspirant
I have u-verse. I purchased the netgear nighthawk X6S router. My u-verse router is 7 years old. So is my u-verse modem. My new netgear nighthawk X6S has no problem communicating with the old u-verse modem. I’m not anticipating any problems when i get my new netgear CM1200 modem.
Aug 27, 2020Guru - Experienced User
IF your on a ATT ISP service, there services don't support cable modems, most of there services for either DSL or Fiber. Pleae contact ATT to ensure what modems are supported by them if any.
