RLKJ
Jan 01, 2023Aspirant
NETGEAR Nighthawk Cable Modem CM1200
Just replaced my Motorola MB8600 Cable Modem with this one. The Motorola was rated up to 1gps. The new Netgear CM1200 is rated up to 2gps. I have Xfinity Gig + Had Xfinity technician at the ...
RLKJ
I read this modem was rated up to 2gps.
What model do you recommend then?
Now about the LAG. ....
Attached is a screenshot of my router. Will this have LAG capability?
Jan 01, 2023Guru - Experienced User
Rated if LAG is enabled.
WIth out LAG, the CM2000 series as a 2.5Gb WAN port.
Something to ask the mfr of that router about and review there support documentation about. It does have a 2.5Gb port so might be better suited for a CM2000 series modem.
