dmart
Jan 06, 2023Aspirant
netgear nighthawk cax80 multi gig port keeps dropping connection
Hello So this issue with the multi gig port dropping connection has me a bit frustrated because I can't figure out what is causing this issue. I have tried different Ethernet cables cat8, cat7 and I...
Jan 07, 2023Guru - Experienced User
dmart wrote:
Hello
So this issue with the multi gig port dropping connection has me a bit frustrated because I can't figure out what is causing this issue. I have tried different Ethernet cables cat8, cat7 and I currently have a cat6a stp plugged in. The drops of internet are random throughout the day from a couple a seconds then it comes back and some days I have no drops. this issue has been going on for about a week an half. I recently build a new pc were the muti gig is connected to which I didn't have this problem for the two weeks after building the pc. Any suggestions are welcome.
Motherboard - Asus Rog Strix z790 - e gaming (which has a 2.5 Gbps Ethernet connection) <What is the brand and model# of the 2.5Gb ethernet adapter on the motherboard? Seen others reported problems with Aqtion and Marvell chipsets.
Realtek doesn't seem to have this problem with the CAX80. Be sure drivers are up to date for this adatper as well. Try a different adapter to test.
Internet Provider and Service - Xfinity Gigabit Extra (speeds up to 1200mbps)
Ethernet Cable - CAT6a STP (25ft) <Does this happen with a shorter cable to test?
What FW version is loaded on the CAX80?
dmart
Jan 08, 2023Aspirant
The motherboard has the 2.5gb connection built in, no adapter. I am using the Intel Ethernet controller and driver is up to date. Do you recommend me switching to Realtek? And I haven’t tried any Ethernet cable shorter than 20ft
- FURRYe38Jan 09, 2023Guru - Experienced User
