dmart
Jan 06, 2023Aspirant
netgear nighthawk cax80 multi gig port keeps dropping connection
Hello So this issue with the multi gig port dropping connection has me a bit frustrated because I can't figure out what is causing this issue. I have tried different Ethernet cables cat8, cat7 and I...
dmart
Jan 08, 2023Aspirant
The motherboard has the 2.5gb connection built in, no adapter. I am using the Intel Ethernet controller and driver is up to date. Do you recommend me switching to Realtek? And I haven’t tried any Ethernet cable shorter than 20ft
Jan 09, 2023Guru - Experienced User
<What is the brand and model# of the 2.5Gb ethernet adapter on the motherboard?
