LaSabana
Dec 21, 2023Aspirant
Netgear Nighthawk CM 2050V Cable Modem
I have a Nighthawk CM 2050V cable Modem and my ISP is Xfinity/Comcast. This unit was purchased in Dec 2021 and therefore out of warranty. I am running Window 11 Home 23H. The issue that I am experie...
Dec 21, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
FYI:
- LaSabanaDec 21, 2023Aspirant
Hi Furrye38, thank you for replying. You have helped me out in the past and I appreciate that. Cable firmware version is V2.01.03. Hardware version is 1.01. I am working on getting to you the other info...connection status and event log. I am having some issue with copy/paste as a reply format.
Acquire Downstream Channel 579000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ Wed Dec 20 13:32:45 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 5; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Wed Dec 20 13:32:31 2023 (Critical (3)) UCD invalid or channel unusable;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Wed Dec 20 13:32:23 2023 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Wed Dec 20 13:32:19 2023 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established (Notice (6)) Honoring MDD; IP provisioning mode = IPv6 Time Not Established (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Tue Dec 19 15:33:12 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 5; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Tue Dec 19 15:32:51 2023 (Critical (3)) UCD invalid or channel unusable;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Tue Dec 19 15:32:43 2023 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Tue Dec 19 15:32:38 2023 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established (Notice (6)) Honoring MDD; IP provisioning mode = IPv6 Time Not Established (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Tue Dec 19 15:29:34 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 5; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Tue Dec 19 15:29:27 2023 (Critical (3)) UCD invalid or channel unusable;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Tue Dec 19 15:29:19 2023 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Tue Dec 19 15:29:14 2023 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established (Notice (6)) Honoring MDD; IP provisioning mode = IPv6 Time Not Established (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Tue Dec 19 13:42:20 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 5; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Tue Dec 19 13:42:04 2023 (Critical (3)) UCD invalid or channel unusable;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Tue Dec 19 13:41:57 2023 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Tue Dec 19 13:41:52 2023 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established (Notice (6)) Honoring MDD; IP provisioning mode = IPv6 Time Not Established (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Wed Dec 13 02:02:20 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 5; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Wed Dec 13 02:01:53 2023 (Critical (3)) UCD invalid or channel unusable;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Wed Dec 13 02:01:45 2023 (Notice (6)) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Wed Dec 13 02:01:40 2023 (Notice (6)) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established (Notice (6)) Honoring MDD; IP provisioning mode = IPv6 Time Not Established (Critical (3)) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Mon Dec 11 12:12:23 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Mon Dec 11 12:07:13 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Mon Dec 11 11:28:51 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Mon Dec 11 11:22:51 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Mon Dec 11 03:05:33 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Mon Dec 11 03:00:24 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Sun Dec 10 07:12:48 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Sun Dec 10 07:06:47 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Sat Dec 09 14:14:17 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 22; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; Sat Dec 09 14:11:30 2023 (Notice (6)) CM-STATUS message sent. Event Type Code: 20; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:3c:d4:10;CMTS-MAC=00:90:f0:6b:02:00;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Dec 21, 2023Guru - Experienced User
Please post the cable connection status page data. IF you need too, copy the page data into a word or word pad app then save off to a .PDF file, then attach that PDF file to your next post.
- LaSabanaDec 22, 2023Aspirant
Hi FURRYe38,
I have the PDF file ready to send however, when I enter to REPLY the BLUE icon located at the bottom left does not allow or open for attachment. This PDF file is about five pages. Please advise. Thank you
