LaSabana
Dec 21, 2023Aspirant
Netgear Nighthawk CM 2050V Cable Modem
I have a Nighthawk CM 2050V cable Modem and my ISP is Xfinity/Comcast. This unit was purchased in Dec 2021 and therefore out of warranty. I am running Window 11 Home 23H. The issue that I am experie...
LaSabana
Dec 23, 2023Aspirant
Hi FURRYe38,
I can't thank you enough for taking the time forward your previous info. I really appreciated, I am going to send three photos of adapters that are located in ISP box and another COMMSCOPE AC Adapter that is installed inline inside the home from one of the lines leading out from the ISP box. If you see anything out of place please advise. But thanks again and I will follow-up with my ISP.
Dec 24, 2023Guru - Experienced User
