patricia2626
Jun 06, 2019Aspirant
Netgear Nighthawk CM1100 DOCSIS 3.1 Cable Modem
I got the cm1100 cable modem docsis 3.1 from amazon and it works but there wierd thing happen regulary the internet stop working then for some minutes reboot it self back on as I keep seeing the mode...
patricia2626
Jun 07, 2019Aspirant
Jun 07, 2019Guru - Experienced User
You have a lot of uncorrectables plus the dynamic range window violation. dynamic range window violation is usually when you're power difference exceeds 12dB. Most usually there's a fault in the line with either a cable, connector, amplifier, etc.
Here's what I'd do for troubleshooting.
1. remove any splitters from the line. (you're power might be a bit to high but its for testing purposes)
2. check all your cables. Make sure the connectors are all good and inspect the cables. I've had a small nick in one give me errors that weren't resolved until I replaced the cable.
3. Hook the modem up directly where it comes into the house. Try not to use any splitters. Just direct connection.
How is the cm1100 wired? CM1100--->Router--Computer? Hopefully. make sure you're not using the 2nd port on the cm1100
