K9cop1142
Mar 11, 2023Aspirant
Netgear Nighthawk CM1150V
I am having a constant problem with loosing signal I have had to reboot the computer / modem /router 4 times again. I have optimum online service . Technician the last time tells me the modem is bad ...
Mar 11, 2023Guru - Experienced User
Do you have a screensnip of the cable connections page and event logs?
Also, if you hardwire a pc/laptop into the modem (without anything else connected) does it stay stable?
- K9cop1142Mar 11, 2023Aspirant
Modem to router to computer hardwired .
- plemansMar 11, 2023Guru - Experienced User
that adds next to nothing.
1. The cable connections page and event logs show us the connection back to the isp
2. I don't really care a whole lot about the router. I don't want it connected to the modem for testing stability.
When you have a modem and a router and you're getting drops, the goal is to simplify down to just modem/pc to ensure that connections stable first and its not a router issue making it seem like a modem issue
Ok but my question is it posible for a modem to work then stop working then after reboot to work.
