K9cop1142
Mar 11, 2023Aspirant
Netgear Nighthawk CM1150V
I am having a constant problem with loosing signal I have had to reboot the computer / modem /router 4 times again. I have optimum online service . Technician the last time tells me the modem is bad ...
Mar 11, 2023Guru - Experienced User
Do you have a screensnip of the cable connections page and event logs?
Also, if you hardwire a pc/laptop into the modem (without anything else connected) does it stay stable?
K9cop1142
Modem to router to computer hardwired .
- plemansMar 11, 2023Guru - Experienced User
that adds next to nothing.
1. The cable connections page and event logs show us the connection back to the isp
2. I don't really care a whole lot about the router. I don't want it connected to the modem for testing stability.
When you have a modem and a router and you're getting drops, the goal is to simplify down to just modem/pc to ensure that connections stable first and its not a router issue making it seem like a modem issue
- K9cop1142Mar 11, 2023Aspirant
Ok but my question is it posible for a modem to work then stop working then after reboot to work.
- FURRYe38Mar 11, 2023Guru - Experienced User
Anything is possible.
We'll may know more if you can post the the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
