plasmabolt007
Feb 11, 2025Initiate
Netgear nighthawk cm1200 question
Hello everyone. I had a power outage and need to make sure my settings are good on my nighthawk cm1200. I am trying to confirm it is set for dynamic IP. The netgear genie has very little options and ...
Feb 12, 2025Guru - Experienced User
All modems are dynamic. There is no user adjustments on modems.
Power OFF both modem and connected router for 30 seconds then back ON with the modem first, then give about 10 seconds and power ON the connected router.
