plasmabolt007
Feb 11, 2025Initiate
Netgear nighthawk cm1200 question
Hello everyone. I had a power outage and need to make sure my settings are good on my nighthawk cm1200. I am trying to confirm it is set for dynamic IP. The netgear genie has very little options and ...
plasmabolt007
Feb 12, 2025Initiate
Thank you to both of you. I was trying to get it going for 3 hours last night after an internet power outage and was about to go buy a new cable router. It works now. Its Alive!
Feb 12, 2025Guru - Experienced User
glad you got it working!
Might mark it solved so others aren't still trying to fix it.
What actually fixed it? (so the next person might know)
