xhasnathx
Dec 08, 2021Tutor
NETGEAR Nighthawk CM2000 - Internet does not work on connected routers
Hello all. I have a NETGEAR Nighthawk CM2000 cable modem that I use with my Comcast Xfinity service. It's been working fine for the past 6 months. Background For the past week, I've been una...
- Dec 08, 2021
You have line issues. your logs are indicating line issues. Your connections page has non-locked channels and errors in several channels.
So start by checking your line inside you home.
Remove any splitters, amplifiers, or signal attenuators from your line. Check the line for kinks, damage, cheap/old/bad/loose/poorly made connections. remove them if you do.
Preferably, move the modem to right where the coax comes into the home. That prevents the wiring in the home from being the issues.
If you're still having the same issues/errors in the line, then the ISP needs to come check the line and not remotely.
Dec 08, 2021Guru - Experienced User
Do you have a screen snip of the cable connections page and the event logs from the modem?
xhasnathx
Dec 08, 2021Tutor
And here is the connection table (attached as file to this reply):
- plemansDec 08, 2021Guru - Experienced User
- xhasnathxDec 08, 2021Tutor
Thank you for the help. I've preemptively scheduled an appointment for a tech to come check it out, but I will follow through on your suggestions meanwhile.
Good plan. Many of the ISP's charge if the issue is internal to the home and not external. So worth trying the moving/checking your own lines first.
Good luck!
