Obsidianstark
Mar 08, 2025Follower
NETGEAR Nighthawk Modem Router Combo (model CAX30) DOCSIS 3.1 Cable Modem and WiFi 6 Router - AX2700
I just purchased the NETGEAR Nighthawk AX6/AX2700 Wi-Fi cable modem router (Model number CAX30) that I can’t hook up yet because I need to purchase adapters that will link it to an external antenna to...
Mar 12, 2025Guru - Experienced User
Sounds like you bought the wrong device.
Sounds like you're trying to setup a point to point system to connect 2 buildings together. the CAX30 isn't what you wanted. Or you needed to explain better because the CAX is for connecting to cable ISP's.
