Deborah2323
May 08, 2022Aspirant
NETGEAR Nighthawk Multi-Gig Cable Modem CM2000
Is it possible to use the Netgear Nighthawk CM2000 in Germany with my Orbi (RBK852) routers? Thanks!
Deborah2323
Does anyone happen to know if I can use my Netgear CM2000 Modem in Germany? And if so, are there any special set up instructions I need to know?
Thanks.
- FURRYe38May 08, 2022Guru - Experienced User
Ask the ISP in country if they support cable modems. Some may not.
Thanks.
- michaelkenwardMay 09, 2022Guru - Experienced User
Thanks.
Maybe someone with the same ISP hangs out here.
So tell people which ISP this is and maybe someone can help.
You could also try here:
NETGEAR Forum - NETGEAR Communities
- olympos1625Jun 07, 2022NETGEAR Employee Retired
Hi @Deborah2323,
Welcome to NETGEAR Community!
Thank you for reaching out. We are sorry for not being able to get back to you immediately. The CM2000 is a North American DOCSIS standard and won't work with European DOCSIS.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
