Deborah2323
May 08, 2022Aspirant
NETGEAR Nighthawk Multi-Gig Cable Modem CM2000
Is it possible to use the Netgear Nighthawk CM2000 in Germany with my Orbi (RBK852) routers? Thanks!
Deborah2323
Does anyone happen to know if I can use my Netgear CM2000 Modem in Germany? And if so, are there any special set up instructions I need to know?
Thanks.
May 08, 2022Guru - Experienced User
Ask the ISP in country if they support cable modems. Some may not.
Thanks.
