Cloud500
Jun 27, 2020Aspirant
netgear nighthawk x10 r9000
Hello my router keeps randomly disconnecting everyday and can be fixed using a factory reset, but today nothing works it just says ethernet cable is not connected or plugged but it is and the internet...
Jun 27, 2020Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
Cloud500
Alright
