iumom1999
Sep 18, 2019Aspirant
NetGear NighthawkX4S C7800
I have the Blink security cameras. They were working fine until I got this new NetGear router. Now I can't get my Blink sync module to connect to the new router. I called Blink Support and he said...
Sep 18, 2019Guru - Experienced User
well its worth a shot at changing passwords. Its pretty simple to do and doesn't take much time.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
I'd also try setting your 2.4ghz radio to channels 1-6-11 and not to auto. If that doesn't work, try setting the 2.4ghz radio speed down temporarily.
iumom1999
Sorry, I don't have any idea what you are talking about when you said changing "the radio".
- plemansSep 18, 2019Guru - Experienced User
in the support page I listed, it has a manual. Not trying to be short but it is very helpful for these questions. "the radio" is your wireless settings. Log into the router (routerlogin.net) and you can go to the wireless section to make changes. These include wireless password, wireless channel broadcasting on, and wireless speeds.
