kkcole1965's avatar
kkcole1965
Follower
Mar 22, 2024
NETGEAR ORBI CBK40 vs CBR40
What is the difference between the Orbi CBK40 and the CBR40?  Also, are either one compatible with Optimum?
Thanks!
  • michaelkenward's avatar
    michaelkenward
    CBK = CBR40 router plus RBS40 satellites.
    Thanks!
    Optimum what? A modem of some sort? Make and model?
  • FURRYe38's avatar
    You'll need to contact Optimum ISP to see if they officially support the CBR40 system with there services since the CBR is a modem with a built in router and wifi system.
