cGDeadly's avatar
cGDeadly
Netgear Portforwarding Problem
Hi, i have a Netgear CG4500BD and a nighthawk. Im having issues at playing a game online with my friends (Minecraft, hosting a server)  it seems as if the CG4500 is the "host" if you will. It has a...
  • DarrenM's avatar
    Oct 29, 2015
    Hello cGdeadly
    You would need to forward the ports on the CG4500BD for the Server and also make sure you have your Nighthawk router set to be a access point which you can get to in Advanced-Advanced setup-Wireless settings then select AP mode.
    DarrenM
