eb3xxx
Jul 20, 2018Aspirant
NETGEAR problems
I have a Netgear c6300. I am thinking of switching to linksys like my buddies if this problem persists.
1. Dosnt let me log into netgear genie. I tried loging in with internet and ethernet, just ha...
eb3xxx
EXACT PROBLEM: https://community.netgear.com/t5/R6000-Series-AC-WiFi-Routers/Forever-loading-animation-timingout/td-p/1102566
DarrenM
Jul 25, 2018Sr. NETGEAR Moderator
Are you able to post your event logs and the power levels of the modem.
DarrenM
- eb3xxxJul 29, 2018Aspirant
can you explain event logs and at this time i just did a speed run on ookla, ping is 16, download is 6.14 and upload is not even running yet, its been a few minutes already.
Ive had to disconnect and refresh for more than 10 minutes in order to go to this website and reply back
i feel like connection is good sometimes getting to a website at like 2 seconds, sometimes 5 seconds or more like today.
this is on my 2.4 wifi not my 5g, my laptop does not support it, it is also in my room 25 feet away from my room with a wall covering
my phone wifi works completely fine 99% of the time, supports 5g and 2.4
but still can never log into genie on 5 or 2.4 unless i reset, then i can for about 30 minutes
while i was typing this i also lost connection
- DarrenMJul 30, 2018Sr. NETGEAR Moderator
You may want to try and adjust the wireless channel of the 2.4 ghz apply the same method I linked below for the 2.4 and 5ghz
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
