Ppiksa1's avatar
Ppiksa1
Netgear r6400
How to connect r6400 to netgear c3000 with built in wifi?
  • You have two options:
    1. Use the C3000 as router and the R6400 as an Access Point.  Enable AP Mode on the R6400.
    2. Use the C3000 as a modem and the R6400 as a router.  Disable router mode on the C3000.
    • TheEther's avatar
      TheEther
      Guru
      ADVANCED > Administration > Router Mode.
      For reference, the manual.
