Senior12's avatar
Senior12
Netgear Router 65 also 3400
I have the above router. All my equipment is hardwired into the router. I have a smart phone which asked me for a password for this router. Where can I find this password? I have all printouts of the Netgear, but cannot find the password for my cell phone for the wireless interface.
  • > Netgear Router 65 also 3400
    > I have the above router. [...]
       That's meaningless.  Look at the product label for an actual model
    number.
    > Model: WNDR3400v3|N600 Wireless Dual Band Router
       Is that accurate?
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual.  Look for "Types of
    Logins" and "Basic Wireless Settings".  Further reading might not hurt,
    either.
    > [...] I have all printouts of the Netgear, [...]
       I have no idea what that means.
  • plemans's avatar
    did you get your wireless password figured out?
    You can log into the device (see manual) and change the wireless name and password. The manual shows you how starting on pge 29.
    Hope this helps.
