smumbauer999's avatar
smumbauer999
Follower
Nov 30, 2020
Netgear router and modem
Ok question so i am wanting to buy a netgear router and modem do i need a coax cable to set up internet or can i connect it via ethernet then connect it to my computer and set wifi on that?
1 Reply
  • plemans's avatar
    Who's your ISP?
    If you're looking for a modem, you first want to make sure its compatible with your isp before buying anything.
    Have you checked with them on compatible modem/routers?
