Ononiwu
Apr 16, 2022Tutor
Netgear Router Default Password Change
Looking to change our router default password but we no longer have support. How do I change the password? Since I no longer have support, I am not seeing any information other than what I can purch...
- Apr 18, 2022
If you factory resets it, it'll get you back to the default login info.
Push and hold reset for 7-15 seconds.
default login: admin
default password: password
all lower case.
You can find your manual here:
https://www.netgear.com/support/product/c7000v2.aspx
Kitsap
Apr 16, 2022Master
In general you do not need support to change your password. The default password that results after a firmware default reset is always the same. From there you can login and change it to what you prefer.
If you would share the specific model number of your router, you will be pointed in the right direction.
