Ononiwu
Apr 16, 2022Tutor
Netgear Router Default Password Change
Looking to change our router default password but we no longer have support. How do I change the password? Since I no longer have support, I am not seeing any information other than what I can purch...
- Apr 18, 2022
If you factory resets it, it'll get you back to the default login info.
Push and hold reset for 7-15 seconds.
default login: admin
default password: password
all lower case.
You can find your manual here:
https://www.netgear.com/support/product/c7000v2.aspx
Apr 17, 2022Guru - Experienced User
https://kb.netgear.com/20026/How-do-I-change-the-admin-password-on-my-NETGEAR-router
Since I no longer have support, I am not seeing any information other than what I can purchase on the Netgear site.
