Oppakj
Apr 19, 2022Aspirant
Netgear router not connecting
Why is my Netgear router not connecting from last week ? even i have checked my entire system
- Apr 19, 2022
1. what router do you have?
2. what firmware is on it?
3. what modem/gateway is it connected to?
4. what are the led's on it doing?
5. did something change?
6. what have you tried doing to fix it?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Apr 19, 2022Guru - Experienced User
