Oppakj's avatar
Oppakj
Netgear router not connecting
Why is my Netgear router not connecting from last week ? even i  have checked my entire system
  • plemans's avatar
    Apr 19, 2022
    1. what router do you have?
    2. what firmware is on it?
    3. what modem/gateway is it connected to?
    4. what are the led's on it doing?
    5. did something change?
    6. what have you tried doing to fix it?
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
