snldub22
Apr 07, 2019Aspirant
Netgear router wifi light not blinking
Router's wifi button is not blinking, I cannot see any wifi signal coming out from router.
1. Tried connecting to Router home page, Since not able to connect to router Routerlogin.net not worki...
snldub22
Thanks for replying.
the rest of the lights( power, LAN1,LAN2, Internet) are working fine.Only WIFI light is not showing up.
Tried the default gaetway site, attached the error. The router homepage is not working /not accessible.
I have tried reseting the router ( more than 30 seconds, 30/30/30 method soemthing which i saw on internet) and other methods to reset the router. but no help.
Apr 07, 2019Guru - Experienced User
What are the lights doing? It helps with diagnostic. You say fine but color, blinking etc.
When you did the reset, did you have to redo the modem? Are you sure you're depressing the button and holding it for long enough? If it reset successfully, it'll make you redo setup. If it isn't, you might be a canidate for a tftp procedure. here's the procedure on how to do so. follow the steps and it should get you through successfully.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
