KC9RPX
Aug 20, 2022Tutor
NETGEAR SUPPORT IS A SCAM
Bought a new Netgear CAX80 router/modem at Best Buy. Quit after a week, paid $481. Returned to Netgear under Warranty, got a refurbished one in return that would not even power on out of box. Calle...
DarrenM
Aug 22, 2022Sr. NETGEAR Moderator
Hello KC9RPX
Do you have a case number from the support that you can PM me?
DarrenM
Aug 26, 2022Guru - Experienced User
Please send the forum moderator a private message with this information.
Thank you.
- KC9RPXAug 26, 2022Tutor
SENT MY RMA AND CASE #
RETURNED TO STORE TOLD HAD TO RETURN TO NETGEAR SO I DID
NETGEAR GOT MY ITEM IN RETURN BY WARRANTY IN MEMPHIS TN WHAREHOUSE
SENT ME IN RETURN ITEM THAT WILL NOT EVEN POWER ON THAT WAS REFURISHED
SAD NETGEAR DOES NOT WANT TO SEND ME AN ITEM THAT WORKS
IN RETURN
I ASK FOR REFUND AND TOLD NO
NOW I AM OUT $481 FOR ROUTE CAX80 THAT I BOUGHT AT BEST BUY
VERY SAD
WHAT TYPE OF COMPANY IS NETGEAR?
SHOULD CARE FOR IT CUSTOMERS, BUT NO
- FURRYe38Aug 26, 2022Guru - Experienced User
I'll have someone contact you.
Thanks I will be waiting. Hope to hear something soon
You have my modem that I returned. I have a modem that wont work that I got in exchange
So now I am without modem that works and also my money
The item I got in return from Netgear would have been know not to work, if it was tested
at the Netgear facility prior to shipping.
