Jason7181
May 14, 2019Aspirant
Netgear switch GS116 V2 will not connect to Netgear C7000-100NAS
Whenever I connect the Netgear C7000-100NAS to the Netgear switch GS116 V2 I loose all internet and wifi. It used to work and then all of a sudden I lost all internet and wifi. I disconnected the GS...
- May 14, 2019
Try a new switch. There cheap on Amazon...
Jason7181
I have tried connecting lan port #1 or #4 of the modem to lan port #1 or #16 on the switch and it still no internet. I have tried all different combinations and still cuts the internet out. I have also unplugged the router and switch and then rebooted both of them. Also have done a factory reset on the modem/router. I'm starting to wonder if the switch is bad. But I'm not sure why it would cut out the internet.
May 14, 2019Guru - Experienced User
Try a different switch to see.
You did swap LAN cabling correct?
Try the switch with a different router if you have one, just connect them gether with a PC to see if it works. You don't have to connet the router to the internet or modem.
