oldcroat
Sep 20, 2016Aspirant
Netgear WiFi Cable Modem Router Model C3700 cannot connect to 2nd Generation Apple TV - Cox cable
I have a Model C3700 which will not connect to Apple TV. Using the Netgear firmware, and click on the Wireless tab. I can see all iphones and ipads connected. I do not see the Apple TV. In additi...
Retired_Member
Sep 20, 2016does apple TV list the c3700 as a saved connection? If yes delete it and re-enter password for WIFI
use wired connection and update Apple TV firmware.
- oldcroatSep 20, 2016Aspirant
Thank you for responding. I will use the Ethernet cable to attach the C3700 to the Apple TV, look in Network? (Not sure in there is section for Saved Connection) and remove the Netgear Wifi. Is that correct?
- Retired_MemberSep 20, 2016
Yes,
Look for a Firmware Update too.
