bosherboi
Feb 01, 2024Star
Netgear WiFi router/modem combo PLEASE HELP!!!
I am in serious need of a new modem/router combo ASAP, DOCSIS 3.1, either dual or tri band, for WiFi 6+ 6E to be able to handle up to 1G with capability to transition and handle WiFi 7 (firmware?). A...
Feb 01, 2024Guru - Experienced User
NG doesn't have any cable modem gateway that support WiFi 6E at the moment. NG doesn't give out on what's on the future production plate either.
CAX30 and 80 only support WiFi 6
I'd get into a separate ISP cable modem unit, something that the ISP supports. Then add on some thing that supports 6Ghz or Wifi 7:
Orbi 960 or 970 series
Nighthawk RS700
bosherboi
Feb 01, 2024Star
So you are suggesting a stand alone modem and add a mesh system instead of a router/modem combo?
I currently use the aforementioned combo (moden/router) and use the DECO W7200 mesh system.
Whether its a stand alone modem or router/modem combo, I need to do something now as the current combo has outlived its usefulness as it only delivers up to 300mbps. My current speeds are 400-600 up to 1G.
What models can you recommend?
- FURRYe38Feb 01, 2024Guru - Experienced User
Take a look at what your ISP supports for stand lone modems. Netgear's CM series model modems are all stand alone. CM2000 series being most available and released to the market. There is a CM3000 that's been on the burner however not due out anytime soon. Not sure when either. That's up to NG and they don't give that info out.
Something CM series if your ISP supports it and then a Orbi MESH system mentioned earlier or if you need a bit cheaper mesh system, review the Nighthawk MK90 series system.
- bosherboiFeb 01, 2024Star
Thank you.
As previously stated, I already use a mesh system. DECO W7200.
Would a stand-alone modem (CM2000 if ISP supports) with my current DECO W7200 be better or would a modem/router Combo (Netgear) with the same mesh system (DECO W7200) be best? Whhich would deliver the highest speeds?
The CM2000 series has 2.5Gb WAN port so there rated for ISP speeds up to this rate. CM1000/11/12 series are 1Gb WAN ports.
You can use your current mesh system behind the CM modem. Can't tell for sure if it has a 1Gb WAN port or 2.5Gb. Would work connected to the CM modem.
