techfreak8
Sep 26, 2016Aspirant
Netgear Wireless Data Cable Gateway firmware update
Netgear CG4500BD Current firmware is 1.03.03. The gui is ancient looks like it is from 2003. I want to update firmware to modern gui genie. Problem is I bought this modem from amazon and not from cox...
DarrenM
Sep 29, 2016Sr. NETGEAR Moderator
Hello techfreak8
All firmware on cable modems come from the ISP you are connected to no way to manually update the firmware.
DarrenM
techfreak8
Sep 29, 2016Aspirant
Alright then if I contact my isp optimun about this issue will they be able to upgrade the firmware?
- DarrenMSep 29, 2016Sr. NETGEAR Moderator
Hello techfreak8
It is very unlikely but you can try typically what happens with firmware is Netgear sends it to the ISP and it then has to get approved by the ISP they do some changes to it and release it on there own schedule.
DarrenM
