Kefisher
Jan 26, 2019Aspirant
NETGEAR05 WAP - C7000 Nighthawk
Hi all,
There is a wireless access point showing-up on my wireless network broadcasting with the ssd NETGEAR05. I can't access it (don't know the password), and although it is listed in the WAP...
DarrenM
Jan 30, 2019Sr. NETGEAR Moderator
Have you checked if its the name of the guest network?
DarrenM
Kefisher
Jan 30, 2019Aspirant
Good thought but I didn’t because I do have a guest network set-up with another id. Was wondering if it might ne associated with my Comcast cable tv service...i know comcast broadcasts a “free” wifi hotspot.
- DarrenMJan 31, 2019Sr. NETGEAR Moderator
That shouldn't happen with a netgear modem/router. Do you have any close neighbors could be a signal from there router.
DarrenM
- KefisherJan 31, 2019AspirantThat’s possible, but then again would a neighbor’s access point show-up in my config settings? No other nearby wifi does.
