WChan
Nov 26, 2024Follower
Netgear34 C6250
any update firmware? The current v1.02.02 that I have
Nov 27, 2024Guru - Experienced User
Something to contact the ISP about since they are the ones that control FW updates on C series modems. Most likely won't see anything since is this is a older generation cable gateway and maybe EoL. So if it's working, continue to use it, if it's not, might be time for something new.
