Cch34
Oct 28, 2021Aspirant
Network disappeared
I tried moving my modem/router and after hooking it up the networks disappeared. The modem lights show it’s on and connected to the internet but none of our devices are seeing the network. I’ve tried...
Oct 29, 2021Guru - Experienced User
Like FURRYe38 says, what actual model device/devices do you have?
thats kind of key.
Do wired devices work?
is it just wireless devices that can't connect?
Did the wifi on/off button get hit? push and hold it for 2 seconds.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Cch34
Oct 29, 2021Aspirant
It’s the c6300v2. Cable modem
Nothing shows up under WiFi on all devices
I’ve tried everything. Even did the factory reset. Is it possible I accidentally hid our network?
- plemansOct 29, 2021Guru - Experienced User
that model has a hardware on/off button for the led. the manual shows it.
Even a factory reset won't work if the hardware button was hit. You need to push and hold it for 2 seconds
- Retired_MemberDec 20, 2021Did you ever fix this? I have the same model and the same problem, just spent the last 2 hours on the phone with Xfinity and they don't know what the issue is. Netgear wants me to pay like 89.99 for a warranty just to try and fix it.
