Cch34
Oct 28, 2021Aspirant
Network disappeared
I tried moving my modem/router and after hooking it up the networks disappeared. The modem lights show it’s on and connected to the internet but none of our devices are seeing the network. I’ve tried...
Cch34
Oct 29, 2021Aspirant
It’s the c6300v2. Cable modem
Nothing shows up under WiFi on all devices
I’ve tried everything. Even did the factory reset. Is it possible I accidentally hid our network?
Oct 29, 2021Guru - Experienced User
that model has a hardware on/off button for the led. the manual shows it.
Even a factory reset won't work if the hardware button was hit. You need to push and hold it for 2 seconds
