Cch34
Oct 29, 2021Aspirant
Networks disappeared
I tried to move our modem/router and after hooking it up and turning it on our networks no longer show up. I have tried unplugging everything, turning the Wi-Fi connection on and off, and the factory ...
Oct 29, 2021Guru - Experienced User
Are you referring to the Wifi SSID name?
Have you setup a new SSID name for each radio on the modem?
Cch34
Oct 30, 2021Aspirant
Yeah I guess it’s the SSID that’s not showing up. The actual modem says it’s connected to the internet and receiving a signal, but non of our devices can see the network. Aka it’s not an option under the WiFi connections and n our devices.
- plemansOct 30, 2021Guru - Experienced User
On the front of the router, 2nd button down is a wifi led on/off button. Try that.
do wired devices work?
- Cch34Oct 30, 2021AspirantWiFi is on.
No devices work. Phones, iPad, desktop…..- plemansOct 30, 2021Guru - Experienced User
Are the lights for 2.4/5 ghz lit up?
You said you factory reset? Pushed and held reset for 7-15 seconds while powered on?
If you log into the router, have you checked to see what ssid/password is set?
