Cch34
Oct 29, 2021Aspirant
Networks disappeared
I tried to move our modem/router and after hooking it up and turning it on our networks no longer show up. I have tried unplugging everything, turning the Wi-Fi connection on and off, and the factory ...
Cch34
Oct 30, 2021Aspirant
Yeah I guess it’s the SSID that’s not showing up. The actual modem says it’s connected to the internet and receiving a signal, but non of our devices can see the network. Aka it’s not an option under the WiFi connections and n our devices.
Oct 30, 2021Guru - Experienced User
On the front of the router, 2nd button down is a wifi led on/off button. Try that.
do wired devices work?
- Cch34Oct 30, 2021AspirantWiFi is on.
No devices work. Phones, iPad, desktop…..- plemansOct 30, 2021Guru - Experienced User
Are the lights for 2.4/5 ghz lit up?
You said you factory reset? Pushed and held reset for 7-15 seconds while powered on?
If you log into the router, have you checked to see what ssid/password is set?
- Cch34Oct 30, 2021AspirantThanks for the help everyone.
I did another factory reset(must not have done it the proper way the first time). And the SSID is back and I can connect via my iPhone. However my browser says I’m not connected to the server. All the proper lights are on on the modem.
