FURRYe38's avatar
New - CAX30 Firmware Version 1.4.10.10 Released
New Features and Enhancements:
•    Stability Improvements
Download Link:
https://www.netgear.com/support/product/cax30.aspx#download
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/
enter your model number in the search box, and click the Documentation button on the product page.
NOTE: This upgrade is for the ROUTER portion of the CAX only. Modem portion Firmware upgrades are pushed down by your ISP. For more information, please see our https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
  • Hi, my CAX30 firmware (modem portion) seems to update on its own even after I downgrade it. Can I stop that. The new firmware isn't working on it.
    • FURRYe38's avatar
      Whats not working on it?
      Did you perform a factory reset and setup from scratch after updating the FW?
      • Fishing4me2's avatar
        Fishing4me2
        Hi, my CAX30 firmware seems to update on its own even after I downgrade it. Can I stop that. The new firmware isn't working on it.
  • Is it normal for the configuration screen to read version 1.4.11.2 after installing this firmware?
    Seems pretty confusing that the package is 1.4.10.10.
      Fishing4me2
      That’s the firmware version that kept updating my router with, but it doesn’t work for me. So far my custom firmware is working great. Hasn’t updated on me yet
      • FURRYe38's avatar
        Not much to go off.
        What do you mean by "kept updating my router"?
        Did you manually download and manually apply the FW update with a wired PC and web browser?
        What doesn't work for you with this version of FW loaded?
