FURRYe38's avatar
New - CAX30 Firmware Version 1.4.11.2 Released
New Features and Enhancements: 11/30/2022
•    Bug Fixes
Download Link:
https://www.netgear.com/support/product/cax30.aspx#download
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/
enter your model number in the search box, and click the Documentation button on the product page.
NOTE: This upgrade is for the ROUTER portion of the CAX only. Modem portion Firmware upgrades are pushed down by your ISP. For more information, please see our  https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This article applies to:
Let us know how it works for you in this thread please.
  • Nighthawk tells me the latest firmware is installed and there are no upgrades. Will this be different if I use a wired PC and browser?
    • Kitsap's avatar
      Kitsap
      Master
      Maybe yes and maybe no.  That is the problem.  Experienced users have more consistent success doing a manual update of their router via a web browser on a computer connected to the router with an Ethernet cable.  In general, download the new firmware (it is in a .zip file) to your computer, unpack the binary (.bin) file from the zip file, log in to the user interface, go the the Advanced -> Administration -> Update Firmware page.
      See details here:  https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
    • FURRYe38's avatar
      Which NIghthawk are you referring too? The Modem or the Nighthawk mobile app?
