Mar 06, 2024Guru - Experienced User
New - CAX30 Firmware Version 2.2.2.2 Released
Bug Fixes: 03/05/2024
Improve WiFi stability.
Enhance system reliability.
Fix security vulnerability issues.
Various bug fixes.
Download Link : https://www.netgear.com/support/produ...
Exive
Mar 25, 2024Aspirant
Is there a specific reason for setting the default DHCP IP address pool range from 192.168.#.100 to 192.168.#.200?
What if I left the pool from 192.168.1.2 to 100? Will it have a connection issue?
Also, do we need to change the IP Address in the LAN TCP/IP Setup, too?
I took a recommendation and set it like this below:
LAN TCP/IP Setup
IP Address
192.168.1.1
IP Subnet Mask
255.255.255.0
(V) Use Router as DHCP Server
Starting IP Address
192.168.1.102
Ending IP Address
192.168.1.150
(I am starting 102 because I don't want to assign 100 and 101 that seems admin IP. This is just my preference)
I am wondering if I need to change the IP address from 192.168.1.1 to 192.168.1.100.
This firmware works better than old 1.x.x.x firmware for me. I had CAX30 in late 2022 with old firmware which continuously dropped the internet when I entered any device to Address Reservation. I ended up returning it. However, I recently purchased CAX30 again and installed 2.2.2.2 firmware and it is more stable.
- FURRYe38Mar 25, 2024Guru - Experienced User
I found years ago that having a smaller default IP address pool size was better and worked better for router systems with smaller count devices connected. The system has less to deal with if you only have 30-50 devices all connected at once. yes you can change this range at any time. My preference as been to use .100 thru .150 for my range since I only have about 30-maybe 40 devices tops. Still has room for new devices.
You can use 192.168.1.1 as this IP address is the reserved IP address for any routers default web page access. So .2 and above can be used. I've never seen a .100 or .101 admin IP addressed web page for access here.
- ExiveMar 25, 2024Aspirant
Thanks for your reply.
If I understood correctly, it is to limit the IP range instead of forcing it to use above 100 (to 200).
Is it still OK if I set it to use 192.168.1.2 to 192.168.1.50?
I was limiting only 50 IP addresses before on Nighthawk c7000v2 (I only have 40 devices)
- ExiveApr 10, 2024Aspirant
I don't think I have an issue after upgrading 2.2.2.2.
As I mentioned earlier, I bought CAX30 from Costco and had issues with the 1.x.x.x versions so I returned it.
I somehow got CAX30 again in 3/2024, and firmware 2.2.2.2 is working well.
Let me share my current config and you can configure similar to it, and see if it works.
Note: I am only sharing the configuration on the Advanced tab. Use a Desktop version of the web browser to access the Admin page.
(o) means the radio button is selected.
(v) means the checkbox selected.
( ) means not selected.
* SETUP
- Internet Setup
- Account Name: CAX30
- Domain Name: Empty
- Internet IP Address: (o) Get Dynamically from ISP
- IP Address: Greyed Out (Note: It was auto-configured)
- IP Subnet Mask: Greyed Out (Note: It was auto-configured)
- Gateway IP Address: Greyed Out (Note: It was auto-configured)
- Domain Name Server (DNS) Address: (o) Use These DNS Servers (Note: It was manually configured)
- Primary DNS: 1.1.1.1
- Secondary DNS: 1.0.0.1
- Tertiary DNS: 0.0.0.0
- Wireless Setup
- Region: United States
- Enable AX: (v)
- Enable OFDMA in 2.4Ghz: (v)
- Enable OFDMA in 5Ghz: (v)
- Enable Smart Connect: ( ) (Note: not selected)
- Wireless Network (2.4Ghz b/g/n/ax)
- Enable SSID Broadcast: (v)
- Enable 20/40 MHz Coexistence: (v)
- Name (SSID): MyWiFiName
- Mode: Up to 860 Mbps
- Channel: Auto (Note: Current 5)
- Transmit Power Control: 100%
- Security Options: WPA2-Personal [AES]
- Password (Network Key): MyWiFiPassword
- Wireless Network (5Ghz a/n/ac/ax)
- Name (SSID): MyWiFiName5G
- Mode: Up to 1801 Mbps
- Channel: 153 (Note: Current : 149 + 153(P) + 157 + 161)
- Security Options: WPA2/WPA3-Personal
- WAN Setup
- Disable IPv4 Firewall Protection: ( ) (Note: not selected)
- Disable Port Scan and DoS Protection: (v)
- Default DMZ Server: ( ) (Note: not selected)
- Respond to Ping on Internet Port: ( ) (Note: not selected)
- MTU Size (in bytes): 1500
- Disable SIP ALG: (v)
- LAN Setup
- Device Name: CAX30
- LAN TCP/IP Setup
- IP Address: 192.168.1.1
- IP Subnet Mask: 255.255.255.0
- Use Router as DHCP Server: (v)
- Starting IP Address: 192.168.1.102 (Note: It was manually configured)
- Ending IP Address: 192.168.1.145 (Note: It was manually configured)
- Address Reservation: (Note: It was manually configured)
* Security
- Access Control
- (v) Turn on Access Control
- (o) Allow all new devices to connect
- Block Sites (Note: Using default, not manually configured)
- Block Services (Note: Using default, not manually configured)
- Schedule (Note: Using default, not manually configured)
- Email: (Note: Using default, not manually configured)
* Advanced Setup: (Note: All using default, not manually configured)
- FURRYe38Apr 10, 2024Guru - Experienced User
Glad it's working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - idealboy89May 07, 2024Tutor
This worked like a charm even with 2.2.2.2
Thank you so much Exive 😊🙏
- Internet Setup
