Mar 06, 2024Guru - Experienced User
New - CAX30 Firmware Version 2.2.2.2 Released
Bug Fixes: 03/05/2024
Improve WiFi stability.
Enhance system reliability.
Fix security vulnerability issues.
Various bug fixes.
Download Link : https://www.netgear.com/support/produ...
Mar 25, 2024Guru - Experienced User
I found years ago that having a smaller default IP address pool size was better and worked better for router systems with smaller count devices connected. The system has less to deal with if you only have 30-50 devices all connected at once. yes you can change this range at any time. My preference as been to use .100 thru .150 for my range since I only have about 30-maybe 40 devices tops. Still has room for new devices.
You can use 192.168.1.1 as this IP address is the reserved IP address for any routers default web page access. So .2 and above can be used. I've never seen a .100 or .101 admin IP addressed web page for access here.
Exive
Mar 25, 2024Aspirant
Thanks for your reply.
If I understood correctly, it is to limit the IP range instead of forcing it to use above 100 (to 200).
Is it still OK if I set it to use 192.168.1.2 to 192.168.1.50?
I was limiting only 50 IP addresses before on Nighthawk c7000v2 (I only have 40 devices)
