Mar 06, 2024Guru - Experienced User
New - CAX30 Firmware Version 2.2.2.2 Released
Bug Fixes: 03/05/2024
Improve WiFi stability.
Enhance system reliability.
Fix security vulnerability issues.
Various bug fixes.
Download Link : https://www.netgear.com/support/produ...
Exive
Mar 25, 2024Aspirant
Is there a specific reason for setting the default DHCP IP address pool range from 192.168.#.100 to 192.168.#.200?
What if I left the pool from 192.168.1.2 to 100? Will it have a connection issue?
Also, do we need to change the IP Address in the LAN TCP/IP Setup, too?
I took a recommendation and set it like this below:
LAN TCP/IP Setup
IP Address
192.168.1.1
IP Subnet Mask
255.255.255.0
(V) Use Router as DHCP Server
Starting IP Address
192.168.1.102
Ending IP Address
192.168.1.150
(I am starting 102 because I don't want to assign 100 and 101 that seems admin IP. This is just my preference)
I am wondering if I need to change the IP address from 192.168.1.1 to 192.168.1.100.
This firmware works better than old 1.x.x.x firmware for me. I had CAX30 in late 2022 with old firmware which continuously dropped the internet when I entered any device to Address Reservation. I ended up returning it. However, I recently purchased CAX30 again and installed 2.2.2.2 firmware and it is more stable.
Exive
Apr 10, 2024Aspirant
I don't think I have an issue after upgrading 2.2.2.2.
As I mentioned earlier, I bought CAX30 from Costco and had issues with the 1.x.x.x versions so I returned it.
I somehow got CAX30 again in 3/2024, and firmware 2.2.2.2 is working well.
Let me share my current config and you can configure similar to it, and see if it works.
Note: I am only sharing the configuration on the Advanced tab. Use a Desktop version of the web browser to access the Admin page.
(o) means the radio button is selected.
(v) means the checkbox selected.
( ) means not selected.
* SETUP
- Internet Setup
- Account Name: CAX30
- Domain Name: Empty
- Internet IP Address: (o) Get Dynamically from ISP
- IP Address: Greyed Out (Note: It was auto-configured)
- IP Subnet Mask: Greyed Out (Note: It was auto-configured)
- Gateway IP Address: Greyed Out (Note: It was auto-configured)
- Domain Name Server (DNS) Address: (o) Use These DNS Servers (Note: It was manually configured)
- Primary DNS: 1.1.1.1
- Secondary DNS: 1.0.0.1
- Tertiary DNS: 0.0.0.0
- Wireless Setup
- Region: United States
- Enable AX: (v)
- Enable OFDMA in 2.4Ghz: (v)
- Enable OFDMA in 5Ghz: (v)
- Enable Smart Connect: ( ) (Note: not selected)
- Wireless Network (2.4Ghz b/g/n/ax)
- Enable SSID Broadcast: (v)
- Enable 20/40 MHz Coexistence: (v)
- Name (SSID): MyWiFiName
- Mode: Up to 860 Mbps
- Channel: Auto (Note: Current 5)
- Transmit Power Control: 100%
- Security Options: WPA2-Personal [AES]
- Password (Network Key): MyWiFiPassword
- Wireless Network (5Ghz a/n/ac/ax)
- Name (SSID): MyWiFiName5G
- Mode: Up to 1801 Mbps
- Channel: 153 (Note: Current : 149 + 153(P) + 157 + 161)
- Security Options: WPA2/WPA3-Personal
- WAN Setup
- Disable IPv4 Firewall Protection: ( ) (Note: not selected)
- Disable Port Scan and DoS Protection: (v)
- Default DMZ Server: ( ) (Note: not selected)
- Respond to Ping on Internet Port: ( ) (Note: not selected)
- MTU Size (in bytes): 1500
- Disable SIP ALG: (v)
- LAN Setup
- Device Name: CAX30
- LAN TCP/IP Setup
- IP Address: 192.168.1.1
- IP Subnet Mask: 255.255.255.0
- Use Router as DHCP Server: (v)
- Starting IP Address: 192.168.1.102 (Note: It was manually configured)
- Ending IP Address: 192.168.1.145 (Note: It was manually configured)
- Address Reservation: (Note: It was manually configured)
* Security
- Access Control
- (v) Turn on Access Control
- (o) Allow all new devices to connect
- Block Sites (Note: Using default, not manually configured)
- Block Services (Note: Using default, not manually configured)
- Schedule (Note: Using default, not manually configured)
- Email: (Note: Using default, not manually configured)
* Advanced Setup: (Note: All using default, not manually configured)
- FURRYe38Apr 10, 2024Guru - Experienced User
Glad it's working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - idealboy89May 07, 2024Tutor
This worked like a charm even with 2.2.2.2
Thank you so much Exive 😊🙏
